Second M03
Started by BrianP., March 25, 2022, 05:42 AM
BrianP.
We have a few routers here that use Fanuc controls. For some reason when runn a tool if you change rpm's from one cut to another it alarms out if an M03 is posted with the change in rpm's. Is there a way to not post additional M03's in a setting or is it a post change?
Thanks
If you use a *sm03 in the post you can force it out
BrianP.
Quote from: JParis on March 25, 2022, 06:04 AMIf you use a *sm03 in the post you can force it out
Force an output of M03?
We want to suppress any additional M03's.
Sorry, I read it too quick...
It's sounds like it's being forced out...find where it's coming from and remove the * on the spindle call
Quote from: JParis on March 25, 2022, 08:10 AMSorry, I read it too quick...
Do that one myself. Like he said need to find the forced call section of the spindle speed and remove the * post might have a force and non force of spindle speed need to see how it is controlling it to get it when you change direction, but not speed.
BrianP.
