Okuma troubles
Started by mkd, September 20, 2022, 01:59 PM
Greetings
current trouble at the moment is a stuck tool changer. Some 1315 barrier alarm won't let me manually put the changer sequence back to home. There is usually and easy 1 step advance procedure.
 having trouble deciphering the jinglishYou cannot view this attachment.
[attachment deleted by admin]
barrier2.png There was a problem during the uploading of barrier2.png.
The upload directory is full. Please contact an administrator about this problem. 51.8 KB
Have you contacted your administrator?  :beer:
Quote from: RobertELee on September 20, 2022, 03:16 PMHave you contacted your administrator?  :beer:
no, but if you know a guy, i'd like to update that one which is really over the top with Jinglish.
Can you hold the interlock release softkey and 1 step advance it?
[Probable Fauty Locations]
(LB35I/LU45-MATC-n By the following state, when turret enters the ATC barrier 1st region Exchange arm is not EA rotation place A or EA rotation place C place status. There is not interference check of ATOC barrier 2, the 3rd regk (LB15I|-MATC-Y) By the following state, when turret enters the ATC barrier 1st region When there is exchange am in EA frontal switching place or EA side is not EAMG place or EA standby place by ATC operation sequent nu When it is not shutter close, when turet enters the ATC barrier regio this alarm generation. There is not interference check of the ATC barrier 3rd region. [Measures to Take]
Perform it in the folowing procedure when this machine is mode to alarm generation state. Please be ATC discretion operation mode. Tum on optional parameter bit No. 33bit. 6ATC barrier cancella operation mode".
Relieve ATC apparatus standby place and dissove an interlerence and turret.
Quote from: Jeff on September 21, 2022, 03:07 AMCan you hold the interlock release softkey and 1 step advance it?
Yeah I did try that. The 1 step advance and reverse buttons are supposed to be illuminated when nothing is blocking the function but they are not. Holding interlock released. Didn't do anything.
 One step advance button does blink if you push it but nothing happens obviously.
 I was considering physically moving the arm but there's quite a drivetrain involved and not sure how to get a hold of anything.
@YoDoug
Help!
Optional parameter 33. Already had the bit six set to a one so I guess that part of the instruction was already satisfied. No clue what that was supposed to do.
Quote from: mkd on September 21, 2022, 05:33 AMHolding interlock released. Didn't do anything.
Just to be certain, there are 2 Interlock Release buttons. One is on the front panel, and the other is the soft key in the ATC menu.
May or may not work though since you have a barrier alarm that I haven't ran into before.
Not aware of a softkey for this.
OSP7000L.
 Thanks for the responses
edit: actually there is one hardkey on the generic OSP panel plus one under the 1 step adv./back.
I have not run a Macturn/Multus with a control older than an E100, however there are a few things about Okuma ATC that are consistent. If you are not getting an overload alarm but cannot step trhough it is usually a signal not being made/changed. My guess is that since the alarm is saying a zone is not correct that the current step may have physically moved into place but there is a sensor that is not agreeing with that move. The op and maintenance book should show a chart of the entire ATC sequence and all of the sensors that need to be made and at what steps. We have 4 multus machines and with those types of ATC hangups it is almost always a chip or sludge/grease build up on a sensor that is causing it. Sometime just taking an air gun and blowing off everything will clear the sensor. The sensors are either going to be prox sensors or laser/IR sensors. There is a particular laser sensor in the B series Multus that builds up sludge from dripping coolant and then it thinks the tool ready pot has not moved back to the magazine side when it physically has.
Quote from: mkd on September 21, 2022, 06:49 AMNot aware of a softkey for this.
Oh, for some reason I was thinking of the OSP300M control.
Derp.
