Can you set the Feedrate Override to a Maximum of 100%
Started by champshire, November 11, 2022, 04:10 AM
I believe this is it
Ingersoll
Material is 304L
400sfm 80ipm .06doc 50% radial step over
It's a weak setup, an 85in diameter plate on knees on an HBM, so I can't push it too hard
Quote from: gcode on November 11, 2022, 03:46 PMIngersoll
We haven't tried those.
I'll post what we use Monday.  I really like them for the long reach stuff.
You could set G999 (or some other random G-Code in the production programs) and it will use O9011 to activate #3004 as follows;
O9011
#3004=1
M99
#6051=999
Then when G999 is commanded, Feed Rate Override is disabled. To turn it back on, set say M30
O9009
#3004=0
M99
#6079=30
Then when M30 is activated it returns
Just a thought.
I've had nothing but good luck annihilating steel with Ingersoll insert milling cutters.
Quote from: CNCAppsJames on November 11, 2022, 11:33 PMYou could set G999 (or some other random G-Code in the production programs) and it will use O9011 to activate #3004 as follows;
O9011
#3004=1
M99
#6051=999
O9009
#3004=0
M99
#6079=30
Just a thought.
Thanks for this. I was thinking subcall a program to set the #3004 as you mentioned but was just going to go G65 to do it. The custom M and G codes are a nice touch. Plus the ability to lock those programs out with Parameter 3202....Should be a solid strategy if the boss man allows me to do it.
On the Ingersoll topic, I run several here. I am really impressed with this guy:
https://www.ingersoll-imc.com/product?ecatProductId=2222247
It has 6 edges per insert and lasts a long time in 32 Rc material (4340ish). 2mm doc, 650 sfm and .040 a tooth.
