Shazam/TPP
:sofa:  :cheers:
Midwest
Quote from: neurosis on January 18, 2022, 02:02 PM
If I am on the go and need to eat I will occasionally grab an Impossible Whopper from BK. They are ok. However, if you look at the nutrition info on most of those plant burgers, they are pure vegan junk food. High in saturated fat, highly processed grains, etc.
Quote from: YoDoug on January 19, 2022, 05:31 AM...if you look at the nutrition info on most of those plant burgers, they are pure vegan junk food. High in saturated fat, highly processed grains, etc.
Very chemically similar to low cost dogfood.
HTM01
Quote from: ghuns on January 19, 2022, 05:50 AMVery chemically similar to low cost dogfood.
dog food is probably better for you  ;D
pmartin
Quote from: HTM01 on January 19, 2022, 06:05 AMdog food is probably better for you  ;D
It might even taste better since it has actual meat in it. ;)
In n out, Whataburger, Whopper, DQ in that order, Plant burger is NOT on the List.
Kinda like buying Meth, Do you really know what's in it??
It's Vegan, It's Plant Based???
WTF does Plant Based Mean??
I ate Broccoli last night and Crapped. Is that plant Based??
BrianP.
BrianP.
