Mummified Aliens Unveiled before Mexican Congress
Started by beej, September 13, 2023, 08:06 AM
beej
Quote from: beej on September 20, 2023, 11:04 AMWormholes fall under travelling faster than the speed of light.  ;D
Do they though?
If The Mexicans ran their Congress like they do their Weather Channels I would move there. 8)
beej
Quote from: Jim at Gentex on September 20, 2023, 11:48 AM#4
Time travel.  :harhar:
time travel falls under worm holes which is under, "traveling faster than the speed of light"  :harhar:
https://www.britannica.com/science/wormhole
Quotewormhole, solution of the field equations in German-born physicist Albert Einstein's theory of general relativity that resembles a tunnel between two black holes or other points in space-time. Such a tunnel would provide a shortcut between its end points. In analogy, consider an ant walking across a flat sheet of paper from point A to point B. If the paper is curved through the third dimension so that A and B overlap, the ant can step directly from one point to the other, thus avoiding a long trek.
The possibility of short-circuiting the enormous distances between stars makes wormholes attractive for space travel. Because the tunnel links moments in time as well as locations in space, it also has been argued that a wormhole would allow travel into the past. However, wormholes are intrinsically unstable. While exotic stabilization schemes have been proposed, there is as yet no evidence that these can work or indeed that wormholes exist.
Quote from: beej on September 20, 2023, 01:17 PMtime travel falls under worm holes which is under, "traveling faster than the speed of light"  :harhar:
Dude !! get over it. have you ever time traveled.....No. :)
Do you think you have time traveled?....Prolly. :)
Taking any Meds? ;D
Wormholes and Light speed are Theories..... ???
It ain't proven till it's done. ::)
And you ain't done it. 8)
P.S. LOL!!! :D
beej
Quote from: Incogneeto on September 20, 2023, 02:28 PMDude !! get over it. have you ever time traveled.....No. :)
Taking any Meds? ;D
P.S. LOL!!! :D
I have time traveled, because I identify as an 18th century puritan and my pronouns are thee, thou. ;)
Funny Funny x 7 View List
Quote from: JakeL on September 21, 2023, 10:28 AMI am terrified to click on that link  :crazy:
I'm for sure not clicking on it at work!!!
Quote from: gcode on September 21, 2023, 11:52 AMI'm for sure not clicking on it at work!!!
Mowens posted it so how bad can it be? :o
Funny Funny x 5 View List
