Exporting Tool library
Started by JParis, January 16, 2024, 09:56 AM
0 Members and 4 Guests are viewing this topic.
Quote from: JParis on January 22, 2024, 09:52 AMctually, no save to a csv, you have to save from Excel to a csv
did it work going into VC?
Quote from: gcode on January 22, 2024, 10:41 AMdid it work going into VC?
Not yet....will it, not sure...says it will..
I need to get my data all formatted properly...that's what I am working on now
Quote from: JParis on January 22, 2024, 09:36 AMI found it...you output the simple report, then once that Active reports window is Open, you do a Save as and choose csv...
I have to reconfigure my Active report to get the info I want out before I can use the csv but it at least gives me a path
Thank you MIL-TFP-41
The only reason I knew this option was there is recently I was saving my tool list as a .pdf file. I was going the print to .pdf route, then I decided to click on the File/Save as button and discovered the options. At the same time I learned that PDF stands for "Portable Document Format", a useless piece of trivia I will never use. It is unfortunate that it doesn't have a .csv option.
If you run Varco Reports I'll bet Jim Varco could add that .CSV option.
Maybe even format it for VC on the fly. Contact and ask him.
I worked with him to output Tool Assy. info to a Haimer Presetter.
Works flawlessly. (.XML data)
<MASTERTOOL>
  <KeyToolId>1100</KeyToolId>
  <ToolDescription>EMC .7500 3F 3FL 6L</ToolDescription>
  <AdapterNo></AdapterNo>
  <AdapterDesc>CAT40</AdapterDesc>
  <ToolTypeDesc>Flat endmill</ToolTypeDesc>
  <ToolImage>\\***\****\****\SHARED MASTERCAM 2022\COMMON\REPORTS\IMG\MTOOL3D21.BMP</ToolImage>
  <isAngleHeadTool>Falsch</isAngleHeadTool>
  <RotationAngle>0</RotationAngle>
  <ToolAngle>0</ToolAngle>
  <midDeviation>0</midDeviation>
  <ahHeight>0</ahHeight>
  <ahWidth>0</ahWidth>
  <shankdiameter>0</shankdiameter>
  <STAGE>
    <CutCount>3</CutCount>
    <Measured>0</Measured>
    <StageType>0</StageType>
    <DataOutput></DataOutput>
    <ReferenceX>0</ReferenceX>
    <ReferenceZ>0</ReferenceZ>
    <ReferenceY>0</ReferenceY>
    <Info></Info>
    <X>19.05</X>
    <UX></UX>
    <LX></LX>
    <Z>172.72</Z>
    <UZ></UZ>
    <LZ></LZ>
    <R>0</R>
    <UR></UR>
    <LR></LR>
  </STAGE>
 </MASTERTOOL>
 <MASTERTOOL>
  <KeyToolId>1101</KeyToolId>
  <ToolDescription>EMC .5000 3F 2FL 4L</ToolDescription>
  <ToolImage>\\****\****\****\SHARED MASTERCAM 2022\COMMON\REPORTS\IMG\MTOOL3D24.BMP</ToolImage>
  <STAGE>
    <Info></Info>
    <X>12.7</X>
    <UX></UX>
    <LX></LX>
    <Z>139.7</Z>
    <UZ></UZ>
    <LZ></LZ>
    <R>0</R>
    <UR></UR>
    <LR></LR>
  </STAGE>
 </MASTERTOOL>
Wait, it's already there, just disabled.
Let me contact Jim and gather intel.
Varco Reports can also Save As Excel XLS and XLSX
CVS is also in the Export list, but it's greyed out.. don't know what that's about
In Varco, Go to Setup Sheet Display settings, CNC Code file Tab, Check CSV Export.
QuoteHi Jim,
Go to Tool Manager, Tool Library, import/export, Report
I don't get the .CSV option there.
QuoteKevin,
That was an oversight on my part that has been fixed for the next update.
