FANUC Custom MACRO B
Started by CNCAppsJames, February 12, 2024, 02:27 PM
Quote from: CNCAppsJames on February 12, 2024, 02:27 PMI figured I'd start this topic here because it seems to get a fair amount of of traffic in manufacturing circles.
It's really nice of you to post this stuff.  Thank you, James!
Quote from: neurosis on March 16, 2024, 05:55 AMIt's really nice of you to post this stuff.  Thank you, James!
Beats keeping it to myself by a long shot. Besides that, it's the best way I know how to honor those that gave so freely to me and helped me work towards my goals and dreams.
Like Like x 4 Thank  You Thank You x 1 View List
Inventor Pro '26 - CAD
Eureka 2026 & CAMplete TruePath 2027 - CAV and Posting
Fusion360 & Mastercam 2027 - CAM
As always... new software toys or discoveries means documentation gets new goodies. :rofl:
What's new: updated terminology, Bookmarks, spell-check, and a few housekeeping items.
You cannot view this attachment.
Like Like x 2 Thank  You Thank You x 1 View List
More of the same... more discoveries and more customer requests.
:coffee:
Like Like x 3 Thank  You Thank You x 1 View List
You guessed it. More of the same. Refining a new template format though...
Added a few FANUC Option part numbers in a section so in case people want to expand their machine's capabilities on that front, the options noted DO NOT require FANUC to install. They can be customer/end user installed so don't let your machine tool dealer con you into paying for a Service Call.
If installing those options noted in the linked to PDF
  • Copy the Option file to a USB/CF Card - usually Rnnnnnnnnn.txt (this is an internal FANUC Reference number)
  • Do a full system backup. This is ALWAYS a good practice when making a change to the machine.
  • Make sure the back up contains your MACRO variables in their current state (values, names, etc...). Usually called "MACRO.TXT"
  • Put the machine in MDI
  • Enable Parameter Write Enable
  • Go to Parameters
  • Press OPRT
  • You may need to right Arrow Soft-Key to OPTION READ
  • type in the option file name including the extension ( Rnnnnnnnnn.txt)
  • Press F SET
  • Press EXEC
  • The message "Please turn off power" appears, turn off / on the CNC power supply. The setting of the option is complete.
  • Turn off Parameter Write Enable
  • Cycle power.
:coffee:
Custom MACRO B - Simplified Guide - Rev-M - Mill
Quote from: CNCAppsJames on November 22, 2026, 03:24 PMthe options noted DO NOT require FANUC to install
After all these years, every day is a school day :clapping:
Quote from: Newbeeee™ on November 22, 2026, 10:59 PMAfter all these years, every day is a school day :clapping:
FANUC has 3 levels of options. One level is where they  must install the option.
A) If an option requires FANUC hardware and software that requires a FANUC Engineer. This is because hardware carries warranty implications.
B) The next level  usually requires either a machine tool builder or machine tool dealer to install because there are usually machine configuration parameters in play and a certain level of expertise to do.
C) The lowest level the end user can install. These don't require any configuration, just installation.
I've done B and C Option installs. Most recently I installed Smart Adaptive Feedrate Control. There's about a dozen parameters involved in that one. Customer didn't want to touch it. :rofl: Service Call it is.
