#25 drill 4.25" deep
Started by Smit, January 19, 2021, 09:50 AM
#15
Quote from: Dan_AKA_ROY23 post_id=6840 time=1613424207 user_id=82I rarely drill. I will soon...
:HIJACK (sort of):
Need to go down 1" in SS 304 using a #17 drill (0.173" dia). There's a lot of holes, 349 to be exact.
Using a VMC mill..
Speeds and feeds? IDK. I have 1.3 ipm at 717 spindle speed (values G Wizard rec'ed) First spot drilling, then peck drill at -0.17" (thru hole).
Help...
:HIJACK OFF (well, similar subject so):
Do you have coolant thru? Mitsubishi MVS0440X08S050 EDP:669329 We run a 4.5mm (.1772) S3170 F9.177 in 304 SST with no pecking.
#16
[quote="Tim Johnson" post_id=7319 time=1614086039 user_id=68]
:HIJACK (sort of):
Using a VMC mill..
Help...
Edit: also no spot drilling. If you feel the need to have a starter hole use a 3D drill. MVS0440X03S050 EDP:666486  The above drill is an 8D drill.
Dan_AKA_ROY23
#17
Waiting on a drill chuck. Old one in the shop no good. Already did spot drilling. Worked out fine.
