OSP Internal Subprograms
Started by JakeL, April 04, 2025, 11:29 AM
We have a production part that we run on our Matsuura's (Fanuc 31i). We're planning on running this part on one of the Okuma's (OSP P300 .. I think). The program uses internal subs, on the Fanuc the format is:
T1 M6
(P1)
G0 G90 G54.1 P1 X1. Y1. S5000 M3
G43 H1 Z1.0
M98Q40001
(P2)
G90 G54.1 P2 X1. Y1.
Z1.0
M98Q40001
M01
M30
N40001 (T1 Sub)
(T1 GCODE)
M99
Will this same format work on the OSP? If not, what is the correct format? (I'm assuming OSP can use internal subs?)
Unfortunately I don't have access to the control right now, but if more information is needed I can get it. Hoping this is a simple question with a simple solution.
Our Okuma VTM-1200 5X lathe with an OSP 300
an internal sub is called like this
N4000 CALL O3064
the end of the main program is M02
The sub is defined as
O3064 (396814_vtm-SUBO3064)
(ROUGH POCKETS)
N100 G00 Z20.23
N110 G94 G01 Z20.13 F125.
the end of the sub is
N1390 RTS  which will loop back to the first line following the
CALL command.
our Postability post outputs this edit free
Like Like x 2 Thank  You Thank You x 1 View List
Thank you! I'll report back if/when we run this.
Quote from: gcode on April 04, 2025, 12:08 PMOur Okuma VTM-1200 5X lathe with an OSP 300
N4000 CALL O3064
I haven't worked much with subs in a LONG time, but I seem to remember Okuma sub calls had to start with a letter after the O.
Like CALL OABCD
Were you always able to use numbers like O1234?  :headscratch:
Quote from: Jeff on April 08, 2025, 04:47 AMWere you always able to use numbers like O1234?  :headscratch:
Using O numbers is the only way I've ever done it.
There was no one here who spoke Okuma when we bought our first one and between the instruction manuals and
Postability's help that's what I came up with.
Given the power built into Okuma's macro language I'm sure there are other ways to call subs.
CALL, MODIN and MODOUT all make use of external subs, afaik.
 A Schedule program might be a good way to organize a series of subs and main
*.SDF
