Metal Removal
Started by gcode, July 15, 2025, 06:13 AM
Aaron
Yeah, it's got some grunt!
I'd be happy to get together with you and show you how I'm attacking it if would help you out, G.   Shoot me an email @ [email protected].
The tool is 5544403 w/ 6019506 Inserts.   Running it at 62.5 IPM @ 1786 RPM (.007 FPT @ 935 SFM).   With a .4" Stepover, and, as mentioned, starting at a .3 DOC at the top, it generally has a bit less than 45% spindle load.
Aaron Eberhard
Vector Manufacturing
Quote from: Aaron on July 23, 2025, 07:51 AMYeah, it's got some grunt!
You have mail  8)
Quote from: gcode on July 23, 2025, 06:11 AMThat Okuma is a powerful machine!
I mostly use Ingersoll 1/2" button cutters and mid feed face mills for roughing
Have you looked at the Sandvik 745 cutters? 14 cutting edges per insert and they are beefy inserts.
https://www.sandvik.coromant.com/en-us/search/products?q=ITEMTYPE:"Tool%20Item"%20PRODFAM:"CoroMill%20745"%20Performance:"Inch"%20HANDValue:"R"&taxonomy=TL%2FMIL%2FMILF%2FMILFI
Gcode is this you running this big ass machine wearing a bicycle helmet?  ;D
Quote from: Aaron on July 22, 2025, 12:12 PMI'm working on a part that made me think of you, G.   I'm starting with an (already turned) blank of A36 that's #3216, and after the first roughing op it's #1908.  This is half of a rotor that'll be pinned together to be finished and then bolted to a diaphragm wall.
I managed to get 'em down to a bit less than 9 hours to do that, so 1308/11 = 118 lb/hr.
That'll do pig.
Warranty=void
Quote from: mkd on August 09, 2025, 04:57 PMWarranty=void
Aaron neglected to mention his side gig as a spindle replacement sales rep.  ::)
