Elijah Tooling INVERT-A-BOLT™ FASTENERS
Started by neurosis, April 13, 2021, 12:50 PM
Has anyone used these things?  I usually just make a back plate and bolt that down to the table for one off type parts. These could save some time if they have good holding force.  I'd need them to hold large blocks of titanium.
https://elijahtooling.com/collections/invert-a-bolt-fasteners/products/1-2inch-invert-a-bolt-fasteners?variant=52467960011">https://elijahtooling.com/collections/i ... 2467960011">https://elijahtooling.com/collections/invert-a-bolt-fasteners/products/1-2inch-invert-a-bolt-fasteners?variant=52467960011
Years back I did...they help a 90lb 7075 plate for roughing
We did find that after roughing we had to retorque them...beyond that, they performed well
Quote from: JParis post_id=9523 time=1618344286 user_id=139We did find that after roughing we had to retorque them...beyond that, they performed well
That's a little scary.  :D
Quote from: neurosis post_id=9525 time=1618344460 user_id=49
I remember finishing a part, it was great no issues, but I go too close to the floor and the material relaxed, the vise and clamps weren't
even tight!! :shock:  :shock:  :shock:
The large size of the part is your friend in that case, because of the weight, so there's that on your side..
Had a customer make us use them on some parts. They were 400 lb TI forgings and they held them with no issues.
Quote from: crazy^millman post_id=9548 time=1618349560 user_id=152Had a customer make us use them on some parts. They were 400 lb TI forgings and they held them with no issues.
We would be holding down 360ish pound blocks with them so that's the kind of feed back I'm looking for.  Thanks.   :thumbsup:
Quote from: neurosis post_id=9570 time=1618394936 user_id=49
Just remember, there is a reason they call him Crazy! :secret:
We were using the Largest ones they make not the smallest ones.
Here are the exact ones. https://elijahtooling.com/collections/invert-a-bolt-fasteners/products/7-8-inch-invert-a-bolt-fastener">//https://elijahtooling.com/collections/invert-a-bolt-fasteners/products/7-8-inch-invert-a-bolt-fastener
