Singularity
Started by mowens, April 13, 2021, 11:54 AM
#15
Quote from: Newbeeee™ post_id=9572 time=1618397935 user_id=157Mike
Out of interest...is this a MTB "fault", because they never had logic to (somehow/PLC/Parameter?) avoid the situation?
Or is this now a post builder/kinematic issue which needs building into your CAM system, so you cannot 'gram a part using the axis at those limits?
And who's footing the bill...
This is what I was leading to. If there were previous meltdowns then the software should have been adjusted to prevent the issue or at least go into e-stop.
I believe Mike worked hand in glove with CGtech developing a VCM for this machine.
It shouldn't be too hard for the guys at CGTech to add tests that warn you when these conditions
are present.
TylerBeer
#17
I've added singularity checks into posts because machines leave bad surface finish near it due to rapid accel/decel or they fault when they hit it (all much like a robot) but I've never heard a crash because of it unless it swings the wrong way into a fixture, that sucks
Quote from: TylerBeer post_id=9585 time=1618410007 user_id=116but I've never heard a crash because of it unless it swings the wrong way into a fixture, that sucks
agreed, this is a fault with machine parameters IMO
I have never seen a machine that doesn't alarm out if told to exceed it's travel limits.
I think it is both. The machine builder is not one the OEMS you normally think of. Their background is in assembly automation; automatic riveting machines, etc. This machine was one of the first they built. I mean, it's an amazing machine.
CGTech wrote our programming software. This is their first foray into the programming side. We were testing a new option they had given us, which caused us to run in a different configuration than normal.
The way I see it we had three opportunities to catch this. Machine, software and programmer. I do think that if this is a well known issue they should have put limits on B axis to keep A and C from approaching parallel.
There is lots of activity going on. I don't think payment  has been decided yet.
It did alarm out but had too much momentum to stop.
This sounds like the sort of crash that needs a video.
It would have been pretty spectacular with all of those ball bearings spewing out.
With a crash of this magnitude, the machine may not be repairable.
You may get it back together to discover it does not perform like it used too because the frame is bent
or it's structure is knocked out of alignment.
On the plus side, I believe this machine is used to wrap carbon fiber sheets on aircraft structures and
± .0001 accuracy is not required.
You are correct about the tolerances. Maintenance has the A axis torn apart so we should know before too long the extent of the damage.
QuoteMaintenance has the A axis torn apart
an easy job as most of it was already self disassembled  :cry:
#25
The Apollo crews had to contend with singularities on their navigation gyroscopes.  They called the phenomenon "gimbal lock".
TylerBeer
#26
Quote from: mowens post_id=9566 time=1618375210 user_id=74
QuoteI smiled at him and Said. "I Know a Guy who just blew up a super expensive Machine"
Glad I could cheer him up!
Yes this machine was somewhere around 8 to 10 million when it was installed in 2009.
holy spamoly  .. too bad you didn't just need, uh, squares:
I talked some more with the operator. I guess I was mistaken. It didn't give us an over travel alarm. It did, however, give us an excessive speed error of some kind.
QuoteIt did, however, give us an excessive speed error of some kind.
that was the poor machine screaming in terror as it blasted through the hard stops  :shock:
Do you have more than one of these machines now, or are you dead in the water right now ??
TylerBeer
#29
Which usually happens close to singularity, unfortunately all inverse kinematics breaks down when you have two possible solutions, so one joint could move "instantly" while the other doesn't, buuuuut since it's not at 0 yet, it tries to get to 'instant' speed, and yavvo. I've seen many a robot cable broken this way, but not a machine crash like that
