Orion Space Craft photos
Started by gcode, April 01, 2026, 12:40 PM
gcode and 1 Guest are viewing this topic.
flicker
I've helped build a lot of parts for the Launch Abort System
Hopefully, it will never be used
Like Like x 6 View List
I knew they were orbiting earth before the slingshot around the moon.
I didn't know it was a 'holding' pattern.
At least they got it sorted so they can let it go!
Quote from: jstell on Today at 09:35 AMI didn't know it was a 'holding' pattern.
It more than a holding pattern.
They are also test the docking and maneuvering systems use to mate with other spacecraft.
"holding" was a joke because they couldn't use the pisser until they got the toilet fan working.
From the article posted above, I love that they use the term "donation".
Quote"Happy to report that toilet is go for use," Mission Control's Capcom Amy Dill radioed back to Koch. "We do recommend letting the system get to operating speed before donating fluid, and then letting it run a little bit after donation."
Quote from: gcode on Today at 11:56 AMIt more than a holding pattern.
If They don't fix the toilet nobodys gonna wanna dock with them.  :o
