Interesting toolpath
Started by gcode, June 03, 2026, 05:12 AM
I've done toolpaths like this a couple of times
but nothing as extreme as this
post on X
Like Like x 4 View List
If you pause the vid at the 4 seconds mark - Back in my DO days, my mentor told me about a job he worked on for Rolls which was similar.
It was for sparking/edm a hole in a blade, and the "banana" electrode had to approach same way to "get up in there".
Long time ago now.... but I'm sure it was all run off hydraulic slides linked to a large custom rotary table, where the fixture/blade was mounted. Rotate the table and everything moved together to position the electrode.
champshire
That's called the G-spot tool path isn't it?
TSmcam
That is a funky turning tool :)
I had a video somewhere (can't find it at the moment), showing a 90 degree head mounted to a B axis on a WFL Mill-Turn, doing 5 axis surface milling within an internal recess on a cylinder bore. A TopSolid/WFL applcations engineer did it at the factory. Similar scenario to above. It was a few years ago, and it really impressed me.
CNC Softwares own 'lil piece of Poison Ivy.
TopSolid for the Win :)
Zoffen
I want to see a larger RAH with one of those tiny RAH Thru Coolant turbine tools in that and then do 5 axis surfacing on the internal front(?) face of the part.
Believe none of what you hear and only half of what you see.
Safety! is no Accident!
gms1
is there a non x link for this? X is forbidden at work.
TSmcam
Quote from: gms1 on June 04, 2026, 03:18 AMis there a non x link for this? X is forbidden at work.
Message me your email address. I just recorded the video for you (it is a pretty short video so emailable) :)
