Cimco Verify for Mastercam
Started by gcode, September 02, 2026, 09:56 AM
I ended up buying the Verify version of Cimco Edit.
It's a really good product.
It's launch time, visual appearance and feature set are really good.
Save as STL is nearly instant and yields very good stl models.
Compare is excellent, far superior to Mastercan Verify Compare.
It also pulls up to 60% of my video card's GPU while running. (Nvidia Quadro RTX A4500)
On the negative side.
You can't load new operations into a session like you can in Mastercam Verify
and you can't bring in wireframe from Mastercam. I like that feature as it's useful for visual reference.
My 3D Connexion Space Pilot never works the first time you launch Cimco Verify, but if you close and relaunch
it works as it should.
I'm currently programming an Okuma 5X trunnion machine and a Cinci 5X gantry mill.
I haven't got the gcode backplot working properly yet, but that's a problem between the seat and key board. I will address it when I get my backlog beat into submission.
It's well worth the $1k they are charging for it.
