Solid Modeling Recommendation (long read)
Started by Leehound, October 11, 2021, 08:30 AM
Quote from: Leehound post_id=17042 time=1634047685 user_id=67Yes, Exactly what I need!
It works pretty slick. It creates the bolt hole clearance for the bolt diameter and the head on the top part and then creates the tap minor diameter for the threads on the bottom.   You can create your own custom processes with different clearance sizes etc or  you can work with their standard library.  If you want to develop your own I *believe* that you have to upgrade to Design Pro. Once you're assemblies are done, you can print out a BOM that gives you a list of hardware used that can get as in depth as you want it to.
If you use TS for machining, the design intent follows you in to the machining side of the software so it automagically knows what size drills, taps, etc to choose to machine the parts. That's another subject.
I'm sure that SolidWorks has something similar for design though I've never used it. I only have the basic license.
#16
Quote from: Leehound post_id=17023 time=1634035089 user_id=67[quote="Thee Byte™" post_id=17018 time=1634014026 user_id=50]
You can do the same kind of generating solids at coordinates in Mastercam as you can in solidworks, I spent all day creating a demo for x9 as a proof of concept.
That's definitely something I could use. What C-hook were you using?
https://theebyte.com/?product=solid-editor-chook-for-mastercam-x9">https://theebyte.com/?product=solid-edi ... stercam-x9">https://theebyte.com/?product=solid-editor-chook-for-mastercam-x9
^ I used this c-hook in the video, It costs 50 USD on my store if you are interested!  :D
#17
Brand new technology huh? :)
#18
Quote from: TSmcam post_id=17062 time=1634065049 user_id=91Brand new technology huh? :)
Well, I made it yesterday, how much newer do u want?  :D
#19
[quote="Thee Byte™" post_id=17064 time=1634065978 user_id=50]
LOL, yeah, well good point :)
#20
Quote from: TSmcam post_id=17070 time=1634072733 user_id=91[quote="Thee Byte™" post_id=17064 time=1634065978 user_id=50]
You also had a point, most of the functionality I use in my products has been around since the inception of X.
I like to think I add something to the mix tho!!
