Tech Exchange
Started by JParis, November 18, 2022, 11:56 AM
Is the Tech Exchange on the Mastercam site gone?
I may be blind I guess but I just don't see it
If you are not logged in you can't see it
I'm having trouble logging in at the moment
edit ... I was able to log in at My Mastercam.com
Once you get logged in, the Tech Exchange is in the Communities drop down
mega
Quote from: gcode on November 18, 2022, 12:12 PMIf you are not logged in you can't see it
That's correct, you will not see it unless logged in,
as a side note, maintenance is required to access the Tech Exchange,
also, your hasp or nethasp codes need to be up to date if applicable, otherwise it will appear to the website that your maint, has expired
Quote from: megabyte on November 18, 2022, 01:38 PMas a side note, maintenance is required to access the Tech Exchange,
That's likely the issue...we're not paid up yet....should have gone out Friday
mega
Quote from: JParis on November 19, 2022, 03:32 AMThat's likely the issue...we're not paid up yet....should have gone out Friday
What files did you want?
Quote from: megabyte on November 20, 2022, 06:02 AMWhat files did you want?
Nothing in particular, I was just going to look..at any rate, I Should have perm coded this morning....I don't install the temp codes, I Know better  :)   unless we are adding product...
Thanks though :cheers:
Quote from: JParis on November 21, 2022, 02:53 AM.I don't install the temp codes, I Know better
True that..
