Mill-Turn question
Started by Jeff, June 07, 2023, 11:02 AM
So I'm just dipping my toes into the mill-turn world and playing with a part.
Can I not have regular vertical mill groups and the mill turn stuff in the same file?
Ever since I added a new mill toolpath group outside of the lathe mill-turn, I'm unable to access the mill-turn group.
Quote from: Jeff on June 07, 2023, 11:02 AMSo I'm just dipping my toes into the mill-turn world and playing with a part.
You can but you have to change the toolpath arrow to that group to access into that group. With MT having different machine groups in a file can be done, but I don't recommend it.
Quote from: crazy^millman on June 07, 2023, 01:03 PMYou can but you have to change the toolpath arrow to that group to access into that group. With MT having different machine groups in a file can be done, but I don't recommend it.
So you're saying that it's best to keep regular files separate from mill turn files?
Quote from: Jeff on June 08, 2023, 03:41 AMSo you're saying that it's best to keep regular files separate from mill turn files?
Your call, but between al the extra planes and the WCS process that uses the Spindle Nose and not the part for MT what a difficult task it becomes managing a file with MT inside of a multi operation part. One customer has 12 different machining operation on a part. 6 individual MT machining operations all broke out into separate files.
Quote from: crazy^millman on June 08, 2023, 04:55 AMYour call, but between al the extra planes and the WCS process that uses the Spindle Nose and not the part for MT what a difficult task it becomes managing a file with MT inside of a multi operation part. One customer has 12 different machining operation on a part. 6 individual MT machining operations all broke out into separate files.
Thank you!
