Set Up Sheets
Started by Hardmill, January 18, 2021, 10:01 AM
Hardmill
So what are we using these days for set up sheets
I have a monkey for set ups now and need a decent set up sheet for him to follow
PEACE :D
I just use active reports and edit the setup sheet with open office.
A long time ago I spent a bunch of time creating my own report but the reports that come with the newer versions of MC aren't too bad.
I was using X+ for a long time but my boss is cheap and X+ is no longer free.   :lol:
I use a customized Active Report.
Varco Reports - super easy to customize.
http://www.varcoreporting.com/">http://www.varcoreporting.com/
What kind of info you want on that sheet Hardmill?
We use a custom application to make the tool list and some error checking from the nc code, then merge the excel sheet with the pdf screenshof from Mastercam.
Hey guy, remember pro grammers setup sheet with the monkeys on it??!😂
Hardmill
Really just tool info and maybe some screen shots
Havent had need for them lately so im a bit behind
Just wanna keep it simple
PEACE :D
Try this one from Glenn Bourman IHS -> https://www.emastercam.com/applications/core/interface/file/attachment.php?id=24262">https://www.emastercam.com/applications ... p?id=24262">https://www.emastercam.com/applications/core/interface/file/attachment.php?id=24262
Zeke has a nice one as well.
If you want to make it from the gcode/nc file instead lemme know, I'll set you up.
Hardmill
#11
[quote="Thee Byte™" post_id=3837 time=1610998872 user_id=50]
You got an example ??
PEACE :D
https://pasteboard.co/JKfOWaa.jpg">https://pasteboard.co/JKfOWaa.jpg
That's just the one we use, the fields and data could be anything you like. The bonus you get from that is that you can setup special conditions for the code, like only allow g54, don;t allow 0 feedrates or spindle speeds, don't allow zdepths more than X, etc...
Hardmill
#14
Better just the tool list and pics
That would confuse the monkey
PEACE :D
