Can't select after export
Started by So not a Guru, January 21, 2021, 05:42 AM
So not a Guru
In 2021, after I export an operation, I can't select anything in the toolpath manager. I have to save & reopen the file before I can continue.
Is anyone else noticing this behavior?
I just exported a bunch of operations and didn't get that behavior.  I went back and exported a single operation to see if that made a difference. It didn't.  It's not hiding the export operation window from you is it?
Try this wrapper for undocumernted functions ->
DllImpExp int OMrefreshOpManTree(bool force);
DllImpExp bool OMenableRefresh(bool on);
Link Address->https://github.com/xx4g/RebuildOpMgrTree">https://github.com/xx4g/RebuildOpMgrTree
License ->
MIT License
Copyright (c) 2021 byte
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
So not a Guru
Quote from: neurosis post_id=4187 time=1611236759 user_id=49I just exported a bunch of operations and didn't get that behavior.  I went back and exported a single operation to see if that made a difference. It didn't.  It's not hiding the export operation window from you is it?
No, I had check that already. I'm gonna have to go to Win 10 before too long I think. I've had a couple of different issues that don't appear to be universal. Just dreading changing over.
[quote="So not a Guru" post_id=4252 time=1611254492 user_id=69]
You aren't using windows 10? Hmm, that shouldn't affect mfc components like the operation manager.
The operation manager still bugs out like that sometimes.
