Camplete 2024 Plugin
Started by Programinator, January 24, 2024, 05:37 AM
Programinator
I have 2024 ready to go on my computer.  I'm being told that I need to stay on 2022 because the Camplete plugin does not work for 23 or 24.  Is this true?  What is the problem?  Anyone have Camplete working with Mastercam 2024 and if so how or what was the problem/fix for getting it working?  Thanks
Mastercam 2022 update 3.1
Dell Precision 7530
Intel i7-8850H, Six Core 2.6GHz, 4.3GHz Turbo, 9MB Processor
32GB NECC RAM 2666MHz
4GB NVIDIA Quadro P2000 Video Card
Running 2024 with Camplete. Are you current with your Camplete maintenance? That would be the only reason I could imagine that someone told you that it doesn't work with current versions.
Our personal Camplete expert, CNCAppsJames is the guy to answer this question.
I suspect he'll be chiming in before too long.
Brad St
Running it here also with no issues. There was a bump in the beginning with the initial release. There was a post here and if I recall James had the fix.
Brad St
Programinator
Quote from: Brad St on January 24, 2024, 06:45 AMHere was the thread I was trying to remember from the other mastercam forum page.
https://www.emastercam.com/forums/topic/106629-is-2024-working-well-or-should-we-stick-with-2023/page/2/
Thanks.  I will send this info to the appropriate guys here and see if they can get it working.  If they get stuck I will let them know that they can maybe DM cncappsjames on eMastercam.  thanks
Dell Precision 7530
Yeah there was an installer issue with CAMplete installing the Plug-In incorrectly.  To the best of my knowledge that issue has been fixed.in the latest build.
Definitely no need to stay on MC 2022.
Programinator
Quote from: CNCAppsJames on January 24, 2024, 07:36 AMYeah there was an installer issue with CAMplete installing the Plug-In incorrectly.  To the best of my knowledge that issue has been fixed.in the latest build.
Maybe they had problems with the install on 23 and just decided to never revisit the problem.  I dont know but I'm trying to get them up to speed because i want to move on to 24.  I dont do anything with Camplete because i just work remotely and send them the Mcam files and at the shop they run it through Camplete.  I hope they get it going because it seems like a waste to keep paying for maintenance on both Mastercam and Camplete and still be stuck on 22.
Dell Precision 7530
