CAMplete for Mastercam 2026 Available
Started by CNCAppsJames, July 24, 2025, 01:03 PM
The CAMplete TruePath Plug-In for Mastercam 2026 is now available.
It is only included in the CAMplete TruePath 2026 installer so you must update if you are still on CAMplete TruePath 2025. I've been running TruePath 2026 since release with no issues.
Plug-Ins available with the latest version of CAMplete TruePath are;
As always, you know where to find me if you have questions.
Like Like x 4 View List
Found a Mastercam 2026 to CAMplete TruePath 2026 bug.
Not a serious one IMHO - Do not use or name levels 999~1001
The CAMplete Plug-In uses Level Names to populate an XML file to pass information;
Level 999
CAMplete Export Settings: [Auto Locate GCS=0][Auto Locate MCS=0][Autocomplete Import=0][Export CAMplete Project Settings=1][Export Fixture=0][Export Part=1]
Level 1000
CAMplete Export Settings: [Export Path=C:\QC\CAMplete TruePath 2026\Mastercam 2026\Mastercam 2026 + CAMplete 2026\][Export Stock=0][Fixture STL By Level=0][Fixture Sel=0][Offset X=0.000000][Offset Y=0.000000]
Level 1001
CAMplete Export Settings: [Offset Z=-3.500000][Part STL By Level=0][Part Sel=0][Project Name=NAS979_ISO-TC39SC2-N2185(2026 - Test)][Stock Sel=0]
When you have Levels 999~1001 already used or named, it causes Mastercam to hang. You then have to End it though the task Manager.
I submitted it this morning.
