Blaser Swisslube Coolant reviews
Started by Here's Johnny!, October 03, 2025, 11:01 AM
Just wondering if this brand is any better then the other stuff on the market? Currently we are using Ometa 900 and we have had it go bad a few times in a few different machines.
The very first question is water quality.
Should be at least soft water, RO (reverse osmosis) is the best.
Hard water is a coolant killer.
As far as coolant, really liking Qualichem so far. We switched from Oemeta.
https://qualichem.com/product/xtreme-cut-250c/
Quote from: kccadcam on October 03, 2025, 11:16 AMThe very first question is water quality.
Blaser said they come in and test the water first and then make a recommendation....that is more then Ometa did or does.
Never been a fan of Blaser.  It seems to go bad just like the rest.  Don't like the smell, and the way it clings to hands.  Not as bad as Hangsterfers.  That stuff you could work 4x10s and on your third day off you could finally eat a sandwich without thinking "mmmm, coolant."  My favorite was Castrol HySol MB50.  Lasted well in machines.  Tool life was good.  Washed from hands well with less lingering odor.  Switched to Ometa 910 after running a bunch of magnesium trashed the Castrol.  Turns out that magnesium is terrible for coolant.  It likes oxygen so well that it becomes an anode and "salts" the machine.  Every exposed metal in the machine gets "soaped" with grey coating kinda like the finish that Apple likes on all their stuff.  And it messes up the pH.
But the thing about Ometa is that they love to run tests and re-balance the emulsifiers and additives.  The Ometa got a little tore up running magnesium as well, but as long as you shop-vac the scum off the top, use an oil skimmer, and don't let it sit uncirculated for too long (a few days, a week) it holds up pretty well.  At a diiferent shop we have had trouble with fungus making a snotty mat on top of the coolant in the tank, partly because of the way the baffles and pump uptake are designed/located in the newer Haas tanks.  It turns the coolant pink with a little bit shiny sheen, instead of the opaque milky that it is when new.  We're able to mitigate it with the rep coming out to re-up the biocides and pH balancers/conditioners, but it does still degrade way faster than my experience at the other shop.
Reach out to your supplier and have them put you in touch with the distributor's rep.
Quote from: jstell on October 03, 2025, 11:21 AMReach out to your supplier and have them put you in touch with the distributor's rep
We had the Ometa team in here...they come in with a about 1 quart bottle wrapped in a cloth so you can't see what it is and pour some into the tank. Then like magic the smell disappears. The Ometa 900 leaves a smell on your hands.
Extreme Cut 250C user here. Very happy.
I saw a video on the internet that said the blaser was the best so maybe i'm wrong... ;D  ;D  ;D  ;D
Quote from: Here's Johnny! on October 03, 2025, 11:28 AMWe had the Ometa team in here...they come in with a about 1 quart bottle wrapped in a cloth so you can't see what it is and pour some into the tank. Then like magic the smell disappears. The Ometa 900 leaves a smell on your hands.
I think you can buy the additives separately and there are several.  I never have, just to not have to deal with more MSDS and chem storage.  It's all stuff that's in the coolant anyway, so once it's added in, the MSDS for the coolant covers it.
Did they take samples from the machines and send them to Utah (US distributor) or Germany to get lab tested for what's depleted or what's in there that shouldn't be?
Quote from: jstell on October 03, 2025, 11:47 AMDid they take samples from the machines and send them to Utah (US distributor) or Germany to get lab tested for what's depleted or what's in there that shouldn't be?
No. They just used some test strips and said to keep the mixture ratio up a little higher (although that didn't seem to matter) around 9-10 on the Brix scale.
gms1
We switched our entire shop to this swisslube in the mid 2000's. I give it a -1/10. At the time we cut probably 85% aluminum with the rest mostly in stainless. I think it took like 3 weeks tops to make that place smell like a fish processing factory on the equator. We used it for about 6 months and switched back to trimsol. I will say that maintenance was a 4 letter word there so nothing was really cleaned/kept up.
Isn't Blaser like $4k per drum?
I think our coolant is $1500. I can't remember the brand name but it's not one of the big boy brands.
Quote from: Jeff on October 27, 2025, 04:09 AMIsn't Blaser like $4k per drum?
The quotes that I have are about 50% more then what we are paying for Ometa.
Shock Shock x 1 View List
