Custom tool - Slitting saw arbor?
Started by neurosis, June 10, 2021, 06:42 AM
I assume that MC still doesn't have the ability to create a tool assembly that has a nut on the bottom side of the tool?
I've done it before in X9.  It works, but stock model doesn't handle it right.  I just put the bottom of the slitting saw at Y0 in the profile file.
It does but as noted, the bottom of the saw will be the Y bottom, the nut is below that
I tried that and it didn't work.  I probably did something wrong. I'll have to play around with it again on Monday.
It doesn't seem as easy to get to work as this.
