Rotating an entire program.
Started by Flycut, November 10, 2021, 02:47 PM
I have a somewhat intricate job with multiple operations and custom work planes on a 4th axis.
What is the best way to spin the part around without messing up those planes?
Rotate your WCS plane
If it's a VMC you'll want to rotate about X
An HMC would rotate about Z
mayday
G0 G90 G54 X0 Y0
G68 X0 Y0 R180
Quote from: gcode post_id=18296 time=1636588580 user_id=60Rotate your WCS plane
I did that but my custom work planes still get messed up.
I just have to go correct them one by one.
Quote from: Flycut post_id=18391 time=1636981265 user_id=122I did that but my custom work planes still get messed up.
Have you tried linking the planes together?
They get "messed up" , what happens exactly?
Quote from: neurosis post_id=18393 time=1636981979 user_id=49
In MAstercam 2022 there is the new parent/child relationship for planes, i think that might be the best solution?
[quote="Thee Byte™" post_id=18394 time=1636982097 user_id=50]
The work plane no longer follows the parts geometry.
I have not.
I'll see if I can in 2020.
mayday
have you considered turning the machine around?
The machine is against a wall.
If I turn it around there won't be enough room to get in there and load it.
Quote from: Flycut post_id=18403 time=1636985628 user_id=122
I have not.
The plane linking was added in 2022 unfortunately.
Quote from: mayday post_id=18409 time=1636988919 user_id=77have you considered turning the machine around?
Quote from: Flycut post_id=18415 time=1636993098 user_id=122The machine is against a wall.
OK then, have you considered turning the whole building around?   :harhar:
mayday
ok, I cant take it anymore
buy a left handed cam system
mayday
#14
Quote from: Newbeeee™ post_id=18597 time=1637272791 user_id=157
You need to put a patio door into the building.
Great for the summer!
OK, so now he has to buy a Patio too?
