Emc
Started by mayday, December 02, 2021, 06:43 AM
Quote from: Newbeeee™ post_id=19193 time=1638531703 user_id=157Hang on - are you boys about to rumble again?
Shall i go get a beer and make myself comfortable?
I would never rumble with him.  I've known him since long before I started hanging out on EMC. I was just ball bustin.  :D
Quote from: YoDoug post_id=19217 time=1638542967 user_id=58What control requires that?
Our old yasnac i80 did.  Not sure if it was due to the machine it was on?  It was a Kitamura Mycenter 4.  The tool changers on those things are weird.
#47
Quote from: RobertELee post_id=19216 time=1638542849 user_id=55
Quote from: gcode post_id=19205 time=1638540121 user_id=60
We're all getting old and the rumbles get pretty boring when everyone breaks for a nap between rounds  :sleep:
https://i.ibb.co/N7Q7nVY/46168953-two-old-men-fighting-illustration.webp">
[quote="Thee Byte™" post_id=19220 time=1638543867 user_id=50]
Quote from: YoDoug post_id=19217 time=1638542967 user_id=58[quote="Thee Byte™" post_id=19212 time=1638542015 user_id=50]
Remind me again why the t1 and m6 have to be on different lines?
Some badly set up okuma i worked with in 2012,
I figured they all were like that.
Those machines arent popular around these parts, mostly due to the controller not being Fanuc.
In older Okuma's if the T* that was being called was already pre-staged the control would alarm. On newer controls there is a parameter that overrides this. Most Okuma users have a custom macro for tool changes, often a G111 or G116 that handles all the logic for tool changes.
#49
What machine needs them to be on separate lines?
I only put them on separate lines if I'm staging a tool while the current tool cuts the part.
T call at the beginning of the path and the M6 call at the end for the next tool.
#50
I've been running Okumas since the mid-90's. I don't recall them ever requiring that.  Maybe there was some kind of special macro the machine was running that wouldn't accept it?
Quote from: Jeff post_id=19231 time=1638546474 user_id=103What machine needs them to be on separate lines?
https://mastercamforums.com/OfftopicForum/viewtopic.php?p=19222#p19222">https://mastercamforums.com/OfftopicForum/viewtopic.php?p=19222#p19222
#52
Quote from: neurosis post_id=19234 time=1638547220 user_id=49
Reported!
#53
Quote from: YoDoug post_id=19229 time=1638546260 user_id=58[quote="Thee Byte™" post_id=19220 time=1638543867 user_id=50]
Yeah, Fanuc doesn't have that problem, see, Fanuc > Okuma  :harhar:
#54
Quote from: Jeff post_id=19236 time=1638547458 user_id=103
Reported!
Ouuu, he got you son, next time bring your reading glasses!!  :w00t:
[quote="Thee Byte™" post_id=19212 time=1638542015 user_id=50]Remind me again why the t1 and m6 have to be on different lines?
That is machine tool builder dependent. Many do not require that. Some require the M06 before the T. It just depends on how they've chosen to do ladder/PMC stuff.
One distinct advantage OSP has over FANUC, it only has to work with/for Okuma. FANUC OTOH... there are literally hundreds (if not thousands) of separate machine tool builders that use that control. All have their ideas on how stuff can/should be done. Okuma is Apple. FANUC is Android. Literally.
thad
#56
Quote from: Newbeeee™ post_id=19336 time=1638701146 user_id=157It would also toolchange without a T# - Just M6 and it would change tools.
It wasn't fussy what # was in the spindle - she'd carry on....
 :shock:
 :rofl:
Using MC2023
