4th axis front
Started by Flycut, March 08, 2022, 08:44 AM
0 Members and 3 Guests are viewing this topic.
What do I have to change so that when I have the part in Front WCS it orientates the same way it would in the mill with the 4th axis on the right.
What I do now is copy the Front WCS then rotate it and every time I need to use it it's 3 extra clicks and mouse drags away.
Create a template file already setup that way and then merge your CAD files into it?
mayday
I never use the WCS, right or left side dont matter, like Ron said create a top front back and bottom template.
dont use default back and bottom as they flip. make a simple solid box and use a solid face to set planes
Is there then a quick way to toggle between these planes with a hot key?
mayday
not that I know of, I undock the plane manager and put it on the other screen. Easy to toggle
Sometimes it's just nice to know I'm not missing somtehing.
Quote from: Flycut on March 09, 2022, 06:45 AMIs there then a quick way to toggle between these planes with a hot key?
view sheets?
I've never used viewsheets for anything.
Will have to  look into that.
Quote from: Flycut on March 09, 2022, 08:35 AMI've never used viewsheets for anything.
Viewsheets will make things SO much easier.
Quote from: mayday on March 09, 2022, 06:31 AMdont use default back and bottom as they flip.
Isn't it just Bottom that flips?
Wow
How long have I been oblivious to this?
#11
Quote from: CADCAM396 on March 09, 2022, 08:11 AMview sheets?
I fought view sheets for the longest time, but that have matured nicely. We still have no view sheet manger like we don't have groups in the Levels manager either, but what a huge time saver view sheets are.
Start by having it open in mill and not design. Try to make up a MMD with the layout like you want, then need to have that MMD be what Mastercam opens with in the defaults. Since I jump between so many different types of machines my default is design to start with.
Quote from: Flycut on March 09, 2022, 08:57 AMWow
5 or 6 versions.
Not so bad considering I'm stuck in 2020 and spent a few years on Gibbs.
mayday
dont forget the stupid auto work offset change. someone is a dumbsmit that never ran a machine
