Edge break at end and/or beginning of toolpath without geometry creation.
Started by Programinator, January 06, 2021, 05:12 AM
[quote="Matthew Hajicek" post_id=2268 time=1610037445 user_id=57]
I got tons of amazed comments about how fast I was.
The only amazed comments about how fast I am come from my girlfriend.
I'm not sure that it's a compliment.   :D
 :sofa:
Programinator
Quote from: JACKOFFALLTRADES post_id=2083 time=1609962648 user_id=110The answer is "Yes, you can fake it", but only in Mastercam 2021 and newer.
Since Mastercam started, you could only do "tangent arcs, that are connected to a tangent or perpendicular line", when using Lead in/out.
Recently, the Lead In/Out "Arc Sweep" parameter, has been enhanced, to now allow a Negative Sweep Angle. This option is used to allow the tool to "roll into the cut", but in your case, you can use it to "round the corner", of a single straight line.
However, it is not as straight-forward, as you might desire, but it will work.
Use a Negative Arc Sweep, to reverse the Arc Entry, and use the Lead In/Out "line", to give your cutter the "approach and exit" moves, from the reversed entry/exit arcs.
NOTE: for this to work, your Entry/Exit Arc Radius, must be equal to your Tool Radius, or the tangency of that cutter versus the "line being cut", will end up in the wrong spot.
 I tried to make it work the way you are describing but i don't think im getting it right.  Maybe a picture would help me.  If you can upload a picture of your lead in/out window that would be great.  Here is what i have.  its for a 1/2 endmill.  Thanks for the help
https://www.emastercam.com/uploads/monthly_2021_01/2053859412_2021-01-0807_40_48-Window.jpg.131993e9c0888d9afd68936ec0ef4ea8.jpg">
Mastercam 2022 update 3.1
Dell Precision 7530
Intel i7-8850H, Six Core 2.6GHz, 4.3GHz Turbo, 9MB Processor
32GB NECC RAM 2666MHz
4GB NVIDIA Quadro P2000 Video Card
Turn off the Gouge Check
Programinator
Nice!!  That eliminates the need to have the extend turned on.  So what i have will make a chamfer at the end of the open chain.  I still have not figured out how to do the radius.  Thanks JParis
Btw according to me mastercam forum this is now logged as an enhancement under R-25483.
Dell Precision 7530
