I need Macros
Started by mayday, October 01, 2022, 06:22 AM
mayday
a tool# check of what's in the spindle for a Toyoda/Fanuc on a restart
3 digit serial# increment with size and spacing percentage
thats it for now  :htu:
In your Tool Change MACRO, immediately following the change, capture #4120 or [#_BUFT]  if you want to use names. After you stage a Tool, #4120 populates with that T#.
For example;
G91G30X0Y0Z0M6
#906=#4120
or
G91G30X0Y0Z0M6
#906=[#_BUFT]
This sends the changed T# in the spindle to MACRO variable #906 immediately after the tool change
After that you can do a check of the current tool in the spindle ( #4320 or [#_ACTT] ) and compare to the variable and do whatever you want.
For example;
IF[#4320NE#906]GOTO9906
M30
N9906#3000=6(TOOL COMPARE FAIL)
Or
IF[[#_ACTT]NE#906]GOTO9906
M30
I only have an 8-Digit MACRO that only scales for size. Will that work?
mayday
mayday
yes I can deal with an 8 digit
it it auto increment?
mayday
