A rookie post question
Started by gcode, February 08, 2023, 07:36 AM
I got a plain jane Version X mpmaster based HMC post here
I've been using it for years with no issues
I sent a file to the floor last week that almost bit me.
It was a dead simple file, with all output at B0.
B0 was omitted. Had the operator not noticed it, we'd have had a very expensive
piece of scrap.
If I add a toolpath that outputs a rotary move, all the operations get B0 output.
Someone has tweaked my post but I can't find the tweak
I've got
rot_on_x = 0   set to zero
but I'm still not getting B output if the file has no rotary motion
Any idea where else I should be looking??
Do those still have a switch to VMC or HMC?
Early in the post in the switches
Yes
I downloaded this from Inhouse in 2008
Obvious question...is it set to HMC?
Might also check the Machine def but 2008 I don't think was hooked up at that point
found it
  if vmc = 0 & tlplnno$ <> 2, sav_rot_on_x = rot_on_x
           if vmc = 1 & tlplnno$ > 1, sav_rot_on_x = rot_on_x
           sav_rot_on_x = rot_on_x    #Uncomment this line to output rotary axis value even when it's not used
It's weird though
I uncommented it and it had no effect
I reloaded the machine and it had no effect
I loaded another machine that post properly and got good result
then I reload the post causing trouble and got good results
N1 (1/4 X 90 MA FORD CARBIDE SPOT DRILL 1" OOH)
(SPOT CHECK 1/4-20 HOLE 1 PLACE)
M11
G00 G17 G90 G54 B0. X2.875 Y.371 S1222 M03
M10
G43 H1 Z2.
Quote from: Newbeeeeâ„¢ on February 08, 2023, 12:00 PMI'm assuming it would have picked this potential problem up....
Not outputting a B rotation value?  I don't believe X+ would have caught that either
Vericut MIGHT have caught this, if it had the proper flags set
