Okuma U100L Parameter Screen - Section Visibility
Started by TSmcam, June 19, 2023, 05:55 PM
We've got an Okuma LB400 lathe with a U100L control. The parameter screens have all be switched off, other than the chuck/tailstock setting, and the User variable screens.
I need to enable the other system parameter screens to change a variable, but there is no option in the available screens to make the other "blanked" screens visible.
Does anyone know how to switch them on?
I only have the Set Add Cal Search Backup and Item soft keys available.
Man I don't miss that control AT ALL. We had the E100M on one of our mills.
I seem to recall either on one of the parameter pages or the mac man page you can use page down instead of Extend and it will give another row of options.
I dont think it is in MacMan. It is some key number sequence that enables the visibility menu.
The E100M is a good controlm just painfully slow on startup. The P300 series we have on our 5 axis and Multitasker are great.
