Set Up Sheets
Started by Hardmill, January 18, 2021, 10:01 AM
#15
Yeah our setup sheet is bloated and stupid. Active reports makes nice pictures and tool list
#16
Have you used active reports before?
Hardmill
#17
[quote="Thee Byte™" post_id=3845 time=1611000675 user_id=50]
Lonng time ago
I opened it and was completely lost
Ill need to get back at it for sure
1st ill take a look at Glenns
Thanks boys
PEACE :D
#18
Nitro pro is good, output to word newbeeee?
Is word preferable to excel?
I can output anything to excel, images/barcodes etc, I didn't know that was something people wanted.. :D
Hardmill
#19
Quote from: Newbeeee™ post_id=3848 time=1611002575 user_id=157You're welcome to my Active reports sheet.
It's effectively a tool list which has a header of customer part number issue etc.
It also outputs stock size and blank Datum calls .
So...you'd have to save as pdf because MC are too cheap to offer the MSWord option.
Then use something like nitro pro to open the pdf and add any info you want - such as datum setting info for each axis.
Then screen snip any views you want and paste them in.
It is a ballache. Nitro was the best i could find that was the most compatible.
Better than adobe editor.
Send it ill take a look
Thanks
PEACE :D
#20
Example from Jim Varco:
http://www.varcoreporting.com/linked/varco_reporting_sample_mill_setup_sheet.pdf">http://www.varcoreporting.com/linked/va ... _sheet.pdf">http://www.varcoreporting.com/linked/varco_reporting_sample_mill_setup_sheet.pdf
Settings:
http://www.varcoreporting.com/linked/varco_reporting_activereports_viewer_screenshots-_setup_sheet.pdf">http://www.varcoreporting.com/linked/va ... _sheet.pdf">http://www.varcoreporting.com/linked/varco_reporting_activereports_viewer_screenshots-_setup_sheet.pdf
Relatively inexpensive, how many hours will you spend tweaking active reports?
Hardmill
#21
Quote from: kccadcam post_id=3857 time=1611006954 user_id=129Relatively inexpensive, how many hours will you spend tweaking active reports?
Not sure since i dont know what the F@%& im doing  :rolleyes:  :rolleyes:
They look really nice
Thanks for the links
PEACE :D
Is your MC current or are you using an older version?
#23
Quote from: Newbeeee™ post_id=3848 time=1611002575 user_id=157Then use something like nitro pro to open the pdf and add any info you want - such as datum setting info for each axis.
I add text lines in the Active Reports Reader before saving as PDF.
Hardmill
#24
Quote from: neurosis post_id=3864 time=1611008326 user_id=49Is your MC current or are you using an older version?
Currently running 2020 but 2021 is installed
2020 because Camplete is not up to date but i can move this project to 2021
PEACE :D
Quote from: kccadcam post_id=3857 time=1611006954 user_id=129Example from Jim Varco:
Nice Mori DuraVertical   I miss mine SO Bad  :cry:  effin' Haas now
Quote from: Hardmill post_id=3871 time=1611011942 user_id=90Currently running 2020 but 2021 is installed
You should give the Mill2 setup sheet a try. It has a pretty clean tool list. If I remember correctly, It didn't have the option for taking screen shots but that's easy to add.  I'll take a couple of screen shots of mine in the morning.  If nothing else, it's one more option for you to look at.
I can't remember for sure, but doesn't that Varco have a free limited version of his setup sheet? edit: never mind that - I just looked and it's a lot more limited than I remember.  :lol:
#27
Steve,
I sent you a couple of youtube videos on customizing setup sheets, it is pretty easy. Check your slack messages.
Have you used the active report setup sheets before?  Do you know how to change between them in the operation manager?
Hardmill
#29
Long time back when they first came out
Ill be taking  shot at it later today
PEACE :D
