Set Up Sheets
Started by Hardmill, January 18, 2021, 10:01 AM
When you select your operations in the operation manager and right click to select setup sheet, click on the setup sheet and hit F2. You'll be able to change to a few different stock setup sheets.  Try the Mill2.
I double checked and the Mill2 doesn't include the option for adding screen shots, but it's really simple to add that to the report.  I'm sure that one of us here can set you up.  If you use the stock setup sheets as a template it's fairly easy to modify them.
Hardmill
#31
Gonna look thru the video John sent and see about editing one
The In House ver that Byte posted dont look bad at all
PEACE :D
Hardmill
#32
Shouldn't be too painful now that im looking into it
Thanks lot boys much appreciated
Gonna just try and make it as painless as possible
Ive always been one to say, "the only stupid question is the one you dont ask"
But this new monkey really does ask some dumb questions
Good thing is it not just me who sees it
PEACE :D
So not a Guru
#33
Steve, I thought I sent this this this morning, but I don't see it. So here is the one I'm using. If you want the files I'll zip them up for you.
https://www.dropbox.com/s/lg497yr4uywg7uc/JAW.pdf?dl=0">https://www.dropbox.com/s/lg497yr4uywg7uc/JAW.pdf?dl=0
Zeke
Hardmill
#34
[quote="So not a Guru" post_id=4098 time=1611169554 user_id=69]
Zeke
Thanks
Ill def take a look
PEACE :D
Shazam/TPP
#35
hey Steve, I thought you had retired and living in Nevada?
:sofa:  :cheers:
Shazam/TPP
#36
QuoteHe's retarded instead.
Similar, but...
i'd give that a thumbs up, or a smiley face but........
oh wait full editor  :thumbsup:  :D
:sofa:  :cheers:
Hardmill
#37
Quote from: Shazam/TPP post_id=4181 time=1611234869 user_id=119hey Steve, I thought you had retired and living in Nevada?
No we moved up there for about 4 yrs
Job went south and got a good offer in Camarillo that brought me back to Cali
Can't wait to move back though
At 56 I still habe a bit to go before retirement.
PEACE :D
Shazam/TPP
#38
bummer i remember you saying how much you loved it there, hopefully they don't move the finish line as we get closer  :cheers:
:sofa:  :cheers:
#39
Quote from: kccadcam post_id=3824 time=1610995299 user_id=129Varco Reports - super easy to customize.
http://www.varcoreporting.com/">http://www.varcoreporting.com/
What we use as well.  :thumbsup:
mike93
#40
Howe do you change  the in house logo  to your own?
Quote from: mike93 post_id=5111 time=1611795826 user_id=61Howe do you change  the in house logo  to your own?
I'm not sure which setup sheet  you're using, but if it's based off of one of the active reports setup sheets -
  • Open the Active Reports designer.
  • Open the report that you're using.  It will have an rpx extension - don't open anything that has a hyphen in front of it unless the image is in a sub-report. example: -Setup Sheet (MILL2-FILE).rpx
  • Click on the image that you want to change
  • Look in the lower right pane for the <image> setting
  • Click the box to the right of it that shows the image path, and select the image that  you want to use. Make sure it's stored somewhere that it will stay.
#42
Some good videos here on active reports.
pmartin
#43
Quote from: neurosis post_id=3818 time=1610993108 user_id=49I just use active reports and edit the setup sheet with open office.
I was using X+ for a long time but my boss is cheap and X+ is no longer free.   :lol:
Ditto that, my boss is cheaper than baby birds. I am sticking with 2019 for now because of X+, hoping that the purse strings loosen.
I like the compact design  of the X+ setup sheet. Now if I could only get the guys to actually READ the darned things. :rant:
QuoteNow if I could only get the guys to actually READ the darned things. :rant:
yup
I've got a Cause and Corrective Action report I need to do
It was a proven program that has made good parts for 5 years
One tool is a wheel cutter, cutting a tight tolerance ceiling on the spindle side of the wheel cutter
It is programmed off the top face of the wheel cutter
The tool list says this
The tool sketch shows it
The man readable code in the file says this
The operator missed it, and set the offset off the bottom of the wheel cutter
Cause of the defect .... programming error!!!!!  :rant:  :rant:
Corrective action ....     slap the guy silly ???????  :popo:  :popo:
