Looking for a drill
Started by gcode, August 08, 2023, 03:04 PM
I'm looking for a thru coolant 1/2 carbide drill
15X is too short and 20x is longer than necessary
does anyone know of a manufacturer than makes a 17 or 18X drill
the material is a cast carbon steel
It's a through hole 8.8" long
Guhring has one with a max drilling depth of 9.014"
They label it as 15xD but all mfg's have different lengths for their ratios I've found.
https://www.guhring.com/ProductsServices/SizeDetails?EDP=9065090127000&fromResults=True
Quote from: Jeff on August 09, 2023, 04:24 AMGuhring has one with a max drilling depth of 9.014"
Walter has a couple they classify as 16xD with a 9.37" drill depth
https://www.walter-tools.com/en-us/search/pages/default.aspx/product/dc170-16-12.700a1-wj30ej
Silly Q ... It looks like they don't make them that big
I've got quotes on both the Guhring and the Titex
Guhring  $607
Titex --- gold plated and sprinkled in diamond dust    $1070
either of these can work .. actual drill depth is 8.8 +.100 breakout
Mitsubishi makes real nice drills too
but their .5 x 15X  is  $515 but only has a 7.55 drill depth
So far I'm thinking the Gurhing is the winner
I haven't had any luck finding other manufacturers
Nachii makes nice drills and a lot of our old tool list call them
out, but their web page and cataloge is so bad I'm gave up looking
Thanks for the help  :cheers:
FYI if you look at OSG, beware that they don't give you max drill depth, just overall flute length which sucks because you never want to drill to the flute washout.
Their 15xd has 230mm flute length.
https://www.osgtool.com/a-brand-ado-6535?page=offering_details&number=653550012&combination=10093
Quote from: Jeff on August 09, 2023, 07:33 AMFYI if you look at OSG, beware that they don't give you max drill depth, just overall flute length which sucks because you never want to drill to the flute washout.
The OSG drill had a nice list price too $527
I've ordered the the Guhring
and will hold it in this
https://us.rego-fix.com/en/search/results?keys=550283250+
Quote from: CNCAppsJames on August 10, 2023, 03:39 PMYou look at Sumitomo?
I have never heard of them, but I will check them out
__
Quote from: gcode on August 10, 2023, 04:56 PMI have never heard of them, but I will check them out
Quote from: Newbeeeeâ„¢ on August 11, 2023, 07:02 AMWhen reading that I thought "someone's hacked G's login"!
Definitely a JB hack, can't drill a hole, doesn't know the brands.... :fish:  :hrhr:  :harhar:
Quote from: __ on August 11, 2023, 08:47 AMDefinitely a JB hack, can't drill a hole, doesn't know the brands.... :fish:  :hrhr:  :harhar:
brand this  :flipbird:       ;D
Funny Funny x 5 View List
Pretty sure the ONLY reason I know of them was because I worked at a Japanese company BITD.
