Water usage
Started by Del., April 25, 2024, 09:44 AM
Del.
How many gallons of water do you guys use a month. I used 5000 gallons last month. It's not even pool or garden season yet. Seems like a lot for 2 people. No leaks.
Quote from: Del. on April 25, 2024, 09:44 AMHow many gallons of water do you guys use a month. I used 5000 gallons last month. It's not even pool or garden season yet. Seems like a lot for 2 people. No leaks.
Don't clean out your fishbowl so much
Like Like x 1 Funny Funny x 5 Thank  You Thank You x 1 View List
Dan_AKA_ROY23
5,000 gallons? In a month?  :headscratch:
Shut off all water use and watch your meter. If it turns at all you have a leak somewhere. Likely a toilet flapper.
DUM1
46 gallons per person per day is the Oregon average, so that is a bit high I would say.
Yeah that seems a bit high, Del. :headscratch:
But the national average is around 80-100 gallons per person per day, so you seem to be in that range.  :yes:
https://www.usgs.gov/special-topics/water-science-school/science/water-qa-how-much-water-do-i-use-home-each-day
You don't have to put fresh water in the bongs every day.
beej
I would check the toilets and see if you have one not shutting off. It's amazing how much water a toilet can use when they keep running.
I used 3750 last month; I have to admit, though, I leave a small stream running in the shower for my cat to drink from. He prefers running water to a bowl. (When he was a kitten we had a leaky shower faucet).
Del.
I'm bad about brushing my tooth and leaving water running. 😂
Leehound
I just check my last water bill. It says my wife and I used 27 gallons for the month. That seems way too low. :o
The bill was for $28.
Shock Shock x 1 View List
 That is a High Bill...(Get it High?) Those weed Plants need Lots of water. ;D
"Hydroponics"?? 8)
And If your Lectric Bill is High. (get it High?)
Turn off the Gro Lights at Night. ::)
Quote from: Del. on April 25, 2024, 01:16 PMI'm bad about brushing my tooth and leaving water running. 😂
It's a really big tooth.
Wait a minute; don't you brush your teeth by soaking them in Polident over night?
Del.
I could save a 1000 gallons a month if I peed in the yard.
Quote from: Del. on April 25, 2024, 03:57 PMI could save a 1000 gallons a month if I peed in the yard.
Don't flush #1's.
Or runny  #2's.   :D
