A Puzzle
Started by gcode, November 15, 2024, 06:39 AM
I posted this on eMC and have stuck out so I thought
I take a break from the political wars and try it here
The machine is a Mori Seiki NT600, 2008 vintage horizontal 5X lathe
The post is from Postability and outputs solid code
The tool path is a simple 3+2 high speed 3D roughing toolpath.
This is the startup code.
When running this code the machine alarms out with a X axis overtravel
at the first motion after calling out G68.1
N6
(ROUGH 1ST DETAIL -B- 11.380 RADS)
G17
M45
T1012
( T12    -  .375 DIA. CARBIDE BULL MILL 1.0FL .03CR  -  H12.    -  D12    -  D0.3750 "  -  R0.0300 " )
G330
G361 B-40. D0.
T1013
G54
M69 (UNCLAMP C)
G28 H0.
U-2. W-2.
G49
G68.1 X.0001 Y0. Z0. I0. J1. K0. R50.
G43 H12.
G97 S7500 M13
G00 X2.6186 Y2.9491 C0. <---- The machine moves  +X -Z and over travels in X
Z10.
M68 (CLAMP C)
M8
Z4.5483
Vericut emulates this motion perfectly ... only the B axis blows through the roof
of the machine, stopping about 10 feet above the spindle
After much trial and error with Vericut I got it to run by making these edits
M69 (UNCLAMP C)
G28 H0.
U-2. W-2.
G49
G68.1 X.0001 Y0. Z0. I0. J1. K0. R50. <----- enable tilted tool plane
G43 H12.
G97 S7500 M13
G00  Y2.9493 C0 <---------- start the comped motion with Y and C axis only
X2.6186 Z10.         <----------- output the comped X and Z values
M68 (CLAMP C)
M8
Z4.5483
This runs perfectly  in Vericut and at the machine.
This makes no sense to me.
Can anyone shed some light on this?
I've gone back through proven files and we've run G68.1 toolpaths multiple times
with no issues at all.
I'm thinking a parameter in the machine ( and in Vericut) are not set properly.
Quote from: gcode on November 15, 2024, 06:39 AMI've gone back through proven files and we've run G68.1 toolpaths multiple times
Can you load one of those older programs and see if you get the same result? Or would that not tell you anything?
Quote from: Jeff on November 15, 2024, 09:36 AMCan you load one of those older programs and see if you get the same result? Or would that not tell you anything?
I put this up on eMC
Ron answered the question
I need a post edit
if Y = 0
first output should be
X Y C
Z
in Y does not equal 0
Y C
X Z
It's seems stupid, but that is exactly the behavior I'm seeing
on the machine and a CGTECH built Vericut machine
Ahh, I haven't been to that site but maybe 3 times since "the great exodus" took place.
