Mastercam 2026 is Available to All Customers!
Started by neurosis, July 01, 2025, 08:18 AM
Quote from: JParis on July 04, 2025, 06:41 AMWell, that $ Canadian I am guessing, so that's about what $6.72 US  :D
It was about $600.00 CAN (I was doing the US conversion).
Quote from: Here's Johnny! on July 04, 2025, 07:02 AMIt was about $600.00 CAN (I was doing the US conversion).
You forgot the Trump Tarrifs  :D
Quote from: gcode on July 04, 2025, 07:20 AMYou forgot the Trump Tarrifs
No way to forget them.... ;)    only problem is they are a moving target!!! :o
In Canadurrrr's defence....the USD to Euro is around 1:1 Bwahahahahaha!!!!
Quote from: CNCAppsJames on July 03, 2025, 09:53 PMUnless Mastercam does a ground up re-write on the UI
Isn't that kind of what they've been doing from release to release?
Changing icons, re-wording functions, etc...
To me, the entire machine group setup dumpster fire shows that it's not working.
They should really work on fixing the current broken things before redoing everything.
For example the Advanced Drill toolpath. What a shit toolpath!
riverhunter
Quote from: Jeff on July 07, 2025, 07:48 AMAdvanced Drill toolpath
I use this one often, for generic probing routines.
Quote from: Jeff on July 07, 2025, 07:48 AMIsn't that kind of what they've been doing from release to release?
Hardly! They are adding some features and modifying others (Modifying mostly for the sake of doing something as opposed to leaving it is my guess...marketing). I am assuming that writing the code/algorithms is more complex as the software progress's, along with adding the items that a licensed from other companies (like the Solid Kernel, Model Prep Tools, Verify, Module Works Toolpaths etc).
No one knows what the end game is with the Machine Setup/ Master Model/ Stock setup. Possibly creating a tiered system that could include G-Code Verification like Vericut or another type?
Not really.
V9 to X,.yes..but that UI was built 25-26 years ago. X to now has been incremental this or that.
"We have run out of money. I guess we'll have to think." Ernest Rutherford
Quote from: Jeff on July 07, 2025, 07:48 AMFor example the Advanced Drill toolpath. What a shit toolpath!
I just used it this morning and it worked perfectly.... using a Postability VTL post
SuperHoneyBadger
UI wise, it's a shitshow that doesn't even feel like it belongs to the same program, IMO - in spite of it's notable utility when used effectively. So I kind of agree with you, the depth table is rudimentary and a little backwards, especially re: speeds/feeds and it feels clunky, yet miraculous when you get it to spit out what you actually wanted it to do.
It really seems like they should have started rewriting the software 10 years ago so that right now they would have a modern platform to add new features to...
IMHO there is no way that Mastercam can compete longterm without it. The framework for advanced functionality doesn't seem to be there and everything just seems bolted on with every new version.
I hope someone can chime in and tell me how wrong i am but....
riverhunter
Quote from: Zoffen on July 07, 2025, 11:29 AMThe framework for advanced functionality doesn't seem to be there and everything just seems bolted on with every new version.
Moving between Mill and Lathe feels like you're using completely different software.  :D
Donald Trump: "second amendment people' could stop Democrat choosing undesirable supreme court justices if she is elected"
