Haas Trunnion Post question
Started by gcode, April 03, 2021, 08:39 AM
#30
Quote from: gcode post_id=10362 time=1619718786 user_id=60
Quote from: mkd post_id=10360 time=1619718212 user_id=155I tried a Ti hogout with my VF-3 in the best case block-on-the-table setup. Epic fail. Something between spindle, drawbar or coolant. Just couldn't get tool life worth a crap. Wouldn't even bother doing Ti on their table top joke-trunnions. Too many better options out there, if you have a solid contract. (I didn't)
this is a small job shop my employer purchased at fire sale prices
the shop has been building these parts with really bad 3D files since 2009.
They were programmed by a contract Catia driver and the CAM files are no longer available.
They are stuck in a loser LTA and must deliver the parts on a regular basis
They currently machine them 3D ... with hours of waterline passes on walls that could be swarfed
on a 5X machine.
Days of bench work and straightening are required to produce a part.
Put the part on a better machine and lose less money (or possibly be profitable), or change the business name and walk away from that project.
 Might just threaten to walk away from it as a needed negotiation tactic. If you're NADCAP/ISO/AS9100, go direct to the prime.
#31
what's a fully loaded MU-6300 with turning cost?
 Seem like if that mom and pop is running Haas, and M560v-5ax would suffice at much less coin.
So not a Guru
#32
Quote from: mkd post_id=10375 time=1619724442 user_id=155what's a fully loaded MU-6300 with turning cost?
Looks like they start at 134K
https://www.okuma.com/products/genos-m560-v">https://www.okuma.com/products/genos-m560-v
