Do you use chooks or nethooks at work?
Started by byte, April 15, 2021, 09:45 AM
What's a chook and nethook?
3 (10.7%)
I never use them.
1 (3.6%)
I seldom use them.
17 (60.7%)
I use them frequently.
7 (25%)
Total Members Voted: 24
Voting closed: April 15, 2021, 09:45 AM
I'm creating a simple poll to get an idea of the demand per x amount of users.
I would appreciate your votes.
 :thumbsup:  :thumbup:
Thanks!
I'll break my "seldom use" down even further
All I use are
Arc3D
FindOverlap
on an even rarer occaions
Rolldie
CoonsSurf
mayday
can you write a voice control hook that allows me to say outloud MC Lathe Sucks
I voted "what's a chook?", not because I don't know what they are but because I use TopSolid.
Gear is the one I get into every now & then. ArcMultiEdit on rare occasions. There could be a shortcut inside of mastercam for these....I just know to find them by hitting Alt-C
Technically the Camplete plugin is a c-hook, but it has its own shortcut inside of Mastercam, so not sure that counts.
Quote from: MIL-TFP-41 post_id=9689 time=1618513300 user_id=111Gear is the one I get into every now & then. ArcMultiEdit on rare occasions. There could be a shortcut inside of mastercam for these....I just know to find them by hitting Alt-C
It definetly counts!
Quote from: mayday post_id=9687 time=1618511843 user_id=77can you write a voice control hook that allows me to say outloud MC Lathe Sucks
 :help:
Quote from: JParis post_id=9685 time=1618509781 user_id=139I'll break my "seldom use" down even further
All I use are
Arc3D
FindOverlap
Rolldie
CoonsSurf
Haha, whenever I show people coons surf they always have some comment .
Quote from: YoDoug post_id=9688 time=1618512894 user_id=58I voted "what's a chook?", not because I don't know what they are but because I use TopSolid.
Hmm note to self, add a "i dont use mastercam" field next time!
I use CoonsSurf FTMFW on almost every project. Nothing flows a 5-Axis toolpath just right like a proper Coons Surface.
Gear is the only one I use. And I only use that about once a month at best.
James has me curious about Coons though, I've heard before that it was very good, I just don't know anything about it.
Dan_AKA_ROY23
Quote from: Jeff post_id=9705 time=1618577900 user_id=103Gear is the only one I use. And I only use that about once a month at best.
Use the same wireframe geo to compare. Coons works similar to NetSurfs. With a Net Surf you don't have to break your geo at every intersection, you will need to before creating your Coons Surf.
Coons and Net look similar but they are not exact (using the same wireframe geo). The data on them is different, also (control points and degree). There's also some more options (blends) available with Coons (linear, parabolic, cubic, cubic slope matching).
I should probably start another thread. :D  but have you played with TS boost milling much?  I"m wondering how it's progressing.
Quote from: Dan_AKA_ROY23 post_id=9708 time=1618580129 user_id=82
This is how your reply looked to me:
"Χρησιμοποιήστε το ίδιο γεωγραφικό πλαίσιο για σύγκριση. Το Coons λειτουργεί παρόμοιο με το NetSurfs. Με το Net Surf δεν χρειάζεται να σπάσετε το γεωγραφικό σας σημείο σε κάθε διασταύρωση, θα πρέπει να το κάνετε πριν δημιουργήσετε το Coons Surf.
Τα κέρματα και το Δίκτυο μοιάζουν παρόμοια αλλά δεν είναι ακριβή (χρησιμοποιώντας το ίδιο wireframe geo). Τα δεδομένα σε αυτά είναι διαφορετικά, επίσης (σημεία ελέγχου και βαθμός). Υπάρχουν επίσης μερικές ακόμη επιλογές (μείγματα) διαθέσιμες με Coons (γραμμική, παραβολική, κυβική, κυβική αντιστοίχιση)."
Yes that's Greek lol
Quote from: neurosis post_id=9709 time=1618580160 user_id=49
We have a few licenses of Boost and a few licenses of Volumill. The Boost is not as picky about stock to leave/corner rounding issues and it allows for finer chip thinning. Boost also calculates faster. However, the in-between cut moves in the machine are not as smooth. We see a lot of "jerky" looking accel/decel type issues in the machine. I have not been able to do a lot of testing though. Unfortunately our programmers are inexperienced, machinists are very busy, and my primary job is controls engineering and robotics so we just live with the Boost toolpath issues.
Dan_AKA_ROY23
Quote from: Jeff post_id=9710 time=1618580605 user_id=103This is how your reply looked to me:
lol. You did post you knew nothing about CoonsSurfs.
What I meant was it is very similar to NetSurfs.
Play around with both of them (CoonsSurfs and NetSurfs)
To create either type of surface, you need a 3D wireframe. So, I suggested use the same wireframe geo for both surface types to compare them.
And NetSurfs don't require geo to be broken at every intersection. CoonsSurfs do require we break the geo.
Quote from: Dan_AKA_ROY23 post_id=9712 time=1618581316 user_id=82
Yeah I've never really messed with surfaces much, just solids.
#14
Quote from: Jeff post_id=9713 time=1618582144 user_id=103
It's fun to draw multiple surfaces into one, and the toolpaths are very smooth.
