Mastercam 2027 Center Drill C-Hook
Started by CNCAppsJames, October 12, 2026, 04:50 PM
This was a C-Hook from Version 8 that never got updated... until Mastercam 2027 :rofl:
I was digging through my code archives and decided to run it through Claude because I could. :rofl:
https://www.dropbox.com/scl/fi/wxiajass7nmkom33hklav/CDrillPt.zip?rlkey=h1i00ukdrz1mose09m0icblp6&dl=0
Description;
Creates points at the correct depth based on the Center Drill selected (00-8 are the centers that are defined) and the circle diameter.
Use;
Launch C-Hook (Alt-C), select C:\Program Files\Mastercam 2027\chooks\CDrillPt\CDrillPt.dll
Select Circle(s)
Select Center Drill
Click OK
Result;
It will create the points on the active level.
Notes;
The Center Drills are defined in C:\Program Files\Mastercam 2027\chooks\CDrillPt\cdrillpt.din file You can open it in any text editor. Maintain current formatting.
There are 5 lines that define the center drill.
Ex;
118.0 Drill tip angle 00
0.025 Drill diameter
0.125 Body diameter
0.03  Drill tip length
60.0  C'sink angle
Mastercam V8 had a 12 Item limit. Mastercam 2027 Has no such limit.
Enjoy.
Any questions, you know where to find me.
Quote from: CNCAppsJames on October 12, 2026, 04:50 PMI was digging through my code archives and decided to run it through Claude because I could.
Got nothing better to do today???   ::)
Quote from: gcode on Today at 08:44 AMGot nothing better to do today???  ::)
Just adding skills to my bag of tricks :P
And it's been on my to-do list for... like years. :rofl:
Quote from: CNCAppsJames on Today at 10:20 AMJust adding skills to my bag of tricks :P
And it's been on my enhancement list for... like years. :rofl:
:fiss cough:
:hrhr:
