Missing Sub
Started by mowens, June 21, 2023, 08:10 AM
Brad St
Quote from: Surface on June 22, 2023, 05:49 AMHumans have always pushed the limits of phyics and engineering, often with tragic results, however it is those pioneers who push the limits of what is possible, encouraging others to go beyond.
Yep, reminds me of Wiley Coyote when you state it like that...he pushed the limits all the time =)
Not making fun of the tragedy of the possible loss of human life though. Their families I hope find peace they were doing what they wanted to do.
thad
Quote from: JakeL on June 21, 2023, 12:19 PMNo way, I think they're still swimming. Takes a long time to swim 2.4 miles up in the ocean
I gotta end a post like this with "/dark humor" or something like that right?
Nah, not here you don't.
Using MC2023
they are reporting that a "debris field" has been found.
"lost communication with the surface every time"
Quote from: gcode on June 22, 2023, 09:21 AMthey are report that a "debris field" has been found.
At least that means those poor schmucks never knew what was happening.
The company was doomed to fail. The company is literally called OceanGate. I mean who thinks its a good idea to put "Gate" as part of the name of your company??
Del.
BBC confirms it's the sub.
Sad Sad x 1 View List
Poor bastids.
I hope they went quick if it imploded.
Del.
Sounds like it imploded about 45 minutes into dive.
Quote from: Jim at Gentex on June 22, 2023, 12:07 PMPoor bastids.
with pressure like that the time between 'Oh shit" and dead is under a second
WW2 submarines were rated to 350 feet and when their hulls failed the 4" thick steel hulls were crushed flat
This vehicle was probably around 10K feet down.
I'm guessing they were dead before they knew there was a problem.
Another option would be that they got their ballast out of balance and "fell" until they hit the ocean floor at which
time the hull imploded.
That vehicle was criminally underpowered and they had nowhere near enough thrust to regain control if they started to
"fall"
If this is how it went, they were not physically suffering, but they did spend quite a while knowing they were
dead men with no hope of surviving the "fall"
the press conference has confirmed that it is the missing submarine and that the debris field
"is consistent with the catastrophic implosion of the pressure hull"
You have to wonder; did they do inspections after each dive? Also is it possible to simulate that kind of pressure in a testing environment?
From what I read about what the company president said about safety this isn't a complete surprise
Quote from: mowens on June 22, 2023, 02:01 PMYou have to wonder; did they do inspections after each dive? Also is it possible to simulate that kind of pressure in a testing environment?
I read that the company that built the carbon fiber hull would only certify it to 6,000 feet
The Titanic is sitting in 12,500 feet of water.
Something like 6500psi per square inch at that depth.
Carbon Fiber has never been tested with enough cycles at that pressure to really know the limits.
They found the end bells made from titanium but the main hull imploded.
At least it was instantaneous.
