Ti Roughing, Low Rigidity Setup?
Started by Matthew Hajicek, February 05, 2021, 02:56 PM
Hoping for some advice.  I've got a very low rigidity setup to get this long plate out of the restricted area of the trunnion.  At first I tried my usual 2D dynamic with a Helical ½" EM to get most of the meat off, but it was flexing and chirping as the cutter rounded the ends, Ti being so rubbery, and chipping the tool.  I got it to work by going down to smaller diameter cutters and four stepdowns, but do you think it would work better to do a contour ramp with a high-feed cutter?  Is there another, better option I haven't though of?
Thanks
https://i.ibb.co/hMzmrhg/Floppy-Plate.png">
https://i.ibb.co/MRBZZxt/DF-Plate-Trunnion-Setup.png">
round  the ends first ????
I do a lot of work like that.  When I have a thin web I never use dynamic. When cuts around the end it causes problems.
I can trick the tool path in to cutting from one direction but I would have to be at work to show you an example.
You could always just use a contour path and cut across that in one direction ?
If you're profiling all the way down, do it in steps so it stays rigid.
I emailed Ron, and he votes highfeed.  Got some on order, won't be here in time for this job but I'll have them for next time.
Thats a good suggestion.  They may still rattle on you at the ends sticking so far out of the clamping area like that.
BrianP.
With all those holes have you thought about fixturing it? Drill holes in blank and then mount to fixture. Be able to get really aggressive on a rigid set up. Extra handling could be offset by decreased cycle times.
Yeah I would go with the head style high feed cutter since they hold up better to abuse than a solid carbide if staying with this method. The other choice mentioned is a good one as well. I would leave it tall and mill to a point, but leaving material to keep it rigid. I would then fixture it and cut off the excess like Brian mentioned.
Those holes are tapered double lead threads, might be challenging to fixture to.  If I had a big enough platter I'd lay it down and cut the top or bottom face complete, flip it over on locators, do the other side, leaving it on tabs.  I spose I could make a larger platter sticking way out there.  I only have to make eight parts for now.  Just tweaking thread sizes on the first one and then I can let'er buck.
I ordered a few of these to play with next time:
https://www.helicaltool.com/products/tool-details-82700">https://www.helicaltool.com/products/tool-details-82700
They seem to cost about the same for the whole tool as for a screw-on tip.
Whats the max depth of cut with those?  about .02?
If you get a lot of vibration on those ends is going to chip that thing out.
Don't take my advise to seriously.  I don't own a Haas 5axis.  :D
If I had to machine that thing with that setup.. I would rotate that down and contour the top with the side of an endmill and then rotate it back up and profile it.
I don't know how you plan to put those holes in?
Quote from: neurosis post_id=6146 time=1612651477 user_id=49If I had to machine that thing with that setup.. I would rotate that down and contour the top with the side of an endmill and then rotate it back up and profile it.
Essentially what I did, but the other way around.  I did the top view 2D dynamic, then the side view 2D dynamic.  Then 45° and semifinish with a bull, flip for the other side.
Quote from: neurosis post_id=6146 time=1612651477 user_id=49I don't know how you plan to put those holes in?
I helix bored them, then I have a custom tapered multi-form threadmill; its the same threadform as on our smaller plates.  Program for double the pitch and you get dual start.  Sizing those out now.
#11
https://i.ibb.co/QQxCJzS/DF-Plate.jpg">
haha.. that photo really puts it in to perspective.
Nice job, Matt.
How do you plan on getting rid of that clamping area?
#14
Thanks!
I'll almost-but-not-quite part it off with a 3mm endmill, then snap it off and sand off the burr.
