Odd chamfer callouts
Started by Jeff, August 22, 2025, 04:07 AM
Lately I'm seeing more and more prints wanting a chamfer on a tapped hole that is smaller than the tap size.
For example an M16 x 2 tap with a 15.8mm x 90 deg called out.
My guess is a simple math error but until you ask, you don't know
Quote from: JParis on August 22, 2025, 04:38 AMMy guess is a simple math error but until you ask, you don't know
That's what I'm guessing is a fuckup on the "engineer".
The standard Helicoil spec calls out a csink smaller than maj dia on smaller dia helicoils.
2-56 maj .109-.113
csink .090 -.110 x 120 deg
I guess you could get a csink if you pushed everything to limits.
Chamfer if probably driven by the minor dia of the hole and then they just did a standard chamfer that they use everwhere else and it just so happens to be a little smaller? Errorginerring at its finest?
Quote from: Zoffen on August 22, 2025, 10:56 AMChamfer if probably driven by the minor dia of the hole and then they just did a standard chamfer that they use everwhere else and it just so happens to be a little smaller? Errorginerring at its finest?
Print just calls out M16 x 2-6H RH thru.
Funny Funny x 1 Crazy Crazy x 1 View List
