Re: Programming
Started by byte, June 20, 2021, 09:29 AM
[quote="Thee Byte™" post_id=12573 time=1624206498 user_id=50]
Hi,
Here are my projects on github if you are interested in coding with Mastercam or Opengl.
https://github.com/theebyte/SystemsManager">https://github.com/theebyte/SystemsManager  <- OpenGl Stl file Renderer with working camera
https://github.com/theebyte/ImporterNethook">https://github.com/theebyte/ImporterNethook  <- import a lot of toolpaths from a lot of different files at once in Mastercam
https://github.com/theebyte/RotatedPlanes">https://github.com/theebyte/RotatedPlanes <- create an association free plane based on an x y or z rotation axis, rotates around the cplane
https://github.com/theebyte/Nethook-TPGrpToNciName-SourceCode">https://github.com/theebyte/Nethook-TPG ... SourceCode">https://github.com/theebyte/Nethook-TPGrpToNciName-SourceCode <-  Rename all the operations in a toolpath group to the group name.
[quote="Thee Byte™" post_id=12574 time=1624206546 user_id=50]
Hi,
Here are my projects on github if you are interested in coding .
https://github.com/xx4g/twlekezexe">https://github.com/xx4g/twlekezexe <- Window Transparency with GDI+ and win32
Check out my new Example of Transparent windows using c++
https://github.com/xx4g/winexe/">https://github.com/xx4g/winexe/
<a href="https://ibb.co/X2tThwn%22%3E%3Cimg">https://ibb.co/X2tThwn"><img src="https://i.ibb.co/X2tThwn/Transparent-Window.png">https://i.ibb.co/X2tThwn/Transparent-Window.png" alt="Transparent-Window" border="0"></a>
//ibb.co/X2tThwn%22%3E%3Cimg%20src=%22https://i.ibb.co/K0WHM1t/Transparent-Window.png%22%20alt=%22Transparent-Window%22%20border=%220%22%3E%3C/a%3E">
[quote="Thee Byte™" post_id=14212 time=1628727684 user_id=50]
You have any screen shots of that?
https://ibb.co/FVSBF5H">https://ibb.co/FVSBF5H
if You download the project the binaries are in the release folder, run winexe.exe to see the results
This is how the interface looks once the opengl 3d mesh viewing tools are integrated, integrated model view and world view camera including selection tools.
I'll need to make a non-dark mode version for Neuro!
#11
What's the transparent windows thingy fur? Inside of Mastercam?
Quote from: Jeff post_id=14450 time=1629203515 user_id=103What's the transparent windows thingy fur? Inside of Mastercam?
You can use them anywhere, it's a software template, it could be used in a stand-alone program or an add-in.
The project is at a new address in a new release,
https://mastercamforums.com/OfftopicForum/viewtopic.php?f=6&t=745">https://mastercamforums.com/OfftopicForum/viewtopic.php?f=6&t=745
here's one of them
