AI be trippin'
Started by mowens, April 07, 2026, 07:55 AM
Quote from: mowens on April 07, 2026, 09:52 AMI can honestly say I have gone 17 years hours without experiencing a Mastercam error.
Fixed.  And that was probably on the Sunday of a three-day weekend!
Or you are talking about the first seventeen years of your life - didn't need mastercam for a paper route!
Either that or you've just outed yourself as not a mastercam user.
I'm talking about the fact that it has been at least 17 years since I last used Mastercam. That was with the original X.
Quote from: mowens on April 07, 2026, 01:25 PMThat was with the original X
But then you got to deal with all the bugs and instability and not-read-for-primetime features!
Not for that long, as I recall. We went to Catia V5.
Surface
I saw this clip today which was funny and also enlightening.
https://x.com/om_patel5/status/2041320039190561169?s=20
"They talk of my drinking but never my thirst." — Scottish proverb
TylerBeer
I open it once in awhile to run a laser or check an old program and most of my parts open with 0kb toolpaths and if I don't have a Mill 3 license I can't regenerate them to backlot. Fun!
TSmcam
The last time I opened MC was, maybe 14 or 15 months ago. I had to extract some geometry to remodel a part.
The last version I used was 2019.
CNC Softwares own 'lil piece of Poison Ivy.
TopSolid for the Win :)
Shazam/TPP
We have Cam Assist and to be honest I haven't played with it that much. the parts that I did use it for, hasn't really helped, there again it could be due to my lack of playing with it. The examples they use are not that complex and the part I sent them when evaluating, they only came to about 60% complete. The powers that be wanted it here for our up and coming engineer  ;)
:sofa:  :cheers:
Quote from: Shazam/TPP on April 08, 2026, 06:20 AMWe have Cam Assist and to be honest I haven't played with it that much. the parts that I did use it for, hasn't really helped, there again it could be due to my lack of playing with it. The examples they use are not that complex and the part I sent them when evaluating, they only came to about 60% complete. The powers that be wanted it here for our up and coming engineer  ;)
But Titan said if you are already using it, you are behind.
"In all my years here and on the old forum I have heard, and likely said, some pretty unhinged stuff. But congrats, you're the new leader in clubhouse."  - ghuns, 6/06/2025
I have not used Mastercam for about 8-9 years. Actually I haven't programmed a part for CNC machine in over a year.
I used Mastercam 2026 just this morning.  Wrangling a coolant turn-on point in my CAMplete NC Format.
In a Matsuura 5-Axis machine with turning capability (CUBLEX or MX-520T) you can't turn on high pressure coolant before the tool edge gets activated.  If you turn it on before, the velocity of the high pressure coolant leaving the turning tool is sufficient to cause the turning tool to rotate.  In turning mode, this causes the machine to alarm because the turning tools should not be rotating ever.  Milling mode has no trouble with this.
Solved it with some IF logic.
I'm probably only in Mastercam 10-20 hours a week anymore. Mostly CAMplete related post tuning.
